[gdal-dev] Trying to build plugins
David Klaus dklaus at carlsonsw.com
Wed Oct 15 13:44:07 PDT 2025
David,
I just wanted to follow up to say that I haven't run into your plugin
problem. So, unfortunately I don't have any advice to offer you here.
Hopefully someone else in the GDAL community has an answer.
On Wed, Oct 15, 2025 at 2:18 PM David Days <david.days at maplarge.com> wrote:
> David and Howard--that definitely helps.  If I pick the right command for
> the --formats call, it shows exactly what was expected when the driver is
> available. [insert facepalm]
> That helps with the core issue of the required support.  I'm still open to
> suggestions about having the plugins show up.  It's not central now, but I
> can see that coming back around to being important some day.
> I really appreciate the fast replies, from both--thanks!
> David
> On Wed, Oct 15, 2025 at 2:12 PM Howard Butler <howard at hobu.co> wrote:
>> On Oct 15, 2025, at 1:02 PM, David Klaus via gdal-dev <
>> gdal-dev at lists.osgeo.org> wrote:
>> I believe in the past I ran into an issue where I couldn't confirm
>> through gdalinfo.exe whether or not a format was available in my build.
>> After some looking around, I realized that some formats were only listed
>> via ogrinfo.exe. Sorry if you already know this or if this information
>> isn't 100% accurate. But, hopefully this helps you,
>> For historical reasons, OGR ~= vector and GDAL ~= raster. These have been
>> more closely unified in the new GDAL CLI – try issuing 'gdal --formats' or
>> 'gdal --formats --json' for a unified set (GDAL 3.11+)
>> Howard
David Klaus
Carlson Software
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251015/ef688d77/attachment.htm>
