[gdal-dev] [gdal 3.12beta1] OGRFeature::GetDefnRef now returns a const pointer
Momtchil Momtchev
momtchil at momtchev.com
Tue Oct 21 11:01:30 PDT 2025
On 21/10/2025 19:08, Even Rouault wrote:
>> Encapsulating the object into a wrapper when returning the object to
>> a language with automatic GC.
>> If I don't do this, I will have to keep a reference to the layer or
>> the feature. Or clone it.
> I see different options:
> 1) we revert that change. Downside: users may believe that they can
> modify the OGRFeatureDefn* instance, which can potentially cause
> crashes if they are OGRFeature* based on it (that was the rationale
> for const'ifying)
> 2) we make OGRFeatureDefn::Reference() and Dereference() const
> methods. But that's a clear violation of const semantics, given that
> we have a GetRefCount() and thus the observable state is modified, so
> not something I'd be super keen doing
> 3) the caller of OGRFeature::GetDefnRef() takes responsibility for
> const_cast'ing the const pointer to a non-const pointer. For the
> purpose of just modifying the ref counter, that's fine.
Just checked and it seems that a plain (non-ref) const shared_ptr can be
copied:
#include<memory>
#include<string>
usingnamespacestd;
intfn1(constshared_ptr<string> s) {
return0;
intfn2(constshared_ptr<string> s) {
returnfn1(s);
intmain() {
constshared_ptr<string>s=make_shared<string>("s");
constshared_ptr<string>s2=s;
fn2(s);
return0;
This is valid even for C++98 without copy ellision.
Momtchil Momtchev<momtchil at momtchev.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251021/5ffcff1f/attachment.htm>
