[gdal-dev] [gdal 3.12beta1] OGRFeature::GetDefnRef now returns a const pointer
Even Rouault even.rouault at spatialys.com
Tue Oct 21 11:17:17 PDT 2025
> Just checked and it seems that a plain (non-ref) const shared_ptr can
> be copied:
I see your point but the situation is a bit different:
- technically copying a const shared_ptr doesn't modify the original
shared_ptr, but the control block encapsulating the raw pointer and the
ref count, shared by all shared_ptr<>.
- Furthermore there is no const method in a shared_ptr<> that would
destroy it. Whereas OGRFeatureDefn::Release() can definitely destroy
"this" when the ref count reaches 0.
http://www.spatialys.com
