[gdal-dev] [gdal 3.12beta] isNaN or isNoData operator
Daniel Baston
dbaston at gmail.com
Sat Oct 25 09:56:00 PDT 2025
GDAL registers its own isnan function with muparser (along with
isnodata and fmod).
What do you mean by "OR and AND are not correct" ?
Dan
On Sat, Oct 25, 2025 at 11:26 AM Momtchil Momtchev via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Alas, muparser NaN behaviour is not perfect. There is no isNaN support
> at all and OR and AND are not correct. I don't know what is his
> background - seems to be astro/space/aviation and definitely not Earth
> sciences. I wonder if the best solution wouldn't be to contribute this
> directly to muparser?
> On 24/10/2025 19:17, Even Rouault wrote:
> > Please file an enhancement ticket about that, especially if you've an
> > API in mind
> > Le 24/10/2025 à 18:55, Momtchil Momtchev via gdal-dev a écrit :
> >> Hello,
> >> I think that you should probably add a way to process (and produce)
> >> NoData (NaN) values to the RasterBand algebra.
> Momtchil Momtchev <momtchil at momtchev.com>
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251025/c6c6f386/attachment.htm>
