[gdal-dev] Proper usage of gdal vsi list
Scott
public at postholer.com
Tue Oct 28 11:58:35 PDT 2025
Thanks for that! The sites you listed worked will with the gdal vsi list
client.
Interestingly, the following worked with your sites as well, but not the
NOAA site:
wget --spider -r --no-parent
https://cdn.star.nesdis.noaa.gov/GOES19/ABI/MESO/18N-76W/GEOCOLOR/ 2>&1
| grep "^--"
On 10/28/25 11:44, Laurențiu Nicola via gdal-dev wrote:
> I was wrong, GDAL actually has code to deal with the autoindex pages: https://github.com/OSGeo/gdal/blob/0f757d0/port/cpl_vsil_curl.cpp#L5024-L5340. It just doesn't work very well with your site:
>>>> gdal.ReadDir("/vsicurl/https://cscie12.dce.harvard.edu/apache/autoindex/")
> ['client-server.gif', 'raspberry.gif', 'raspberry.jpg', 'raspberry.png', 'slide1.html', 'slide2.html', 'slide3.html']
>>>> gdal.ReadDir("/vsicurl/https://nginx.org/packages/")
> ['aix', 'alpine', 'amzn', 'centos', 'debian', 'keys', 'rhel', 'sles', 'ubuntu', 'mainline']
>>>> gdal.ReadDir("/vsicurl/https://cdn.star.nesdis.noaa.gov/GOES18/ABI/MESO/M1/GEOCOLOR/")
> (nothing)
> Laurentiu
> On Tue, Oct 28, 2025, at 20:31, Scott via gdal-dev wrote:
>> But, the docs say:
>> gdal vsi list list files of GDAL Virtual File Systems (compressed,
>> network hosted, etc...): /vsimem, /vsizip, /vsitar, /vsicurl, ....
>> ...so this implies http dir listings via /vsicurl. I may be interpreting
>> that incorrectly, though.
>> Scott
>> On 10/28/25 11:17, Laurențiu Nicola via gdal-dev wrote:
>>> I'd be quite surprised if GDAL's vsicurl was able to understand a directory index.
>>> Take https://cscie12.dce.harvard.edu/apache/autoindex/, for example, it's clear that's a directory with 7 files, but it also has a bunch of column sorting links you'd want to ignore.
>>> To be fair, there aren't that many directory index formats, but I'm not sure that parsing them is a job for GDAL.
>>> Laurentiu
>>> On Tue, Oct 28, 2025, at 18:28, Scott via gdal-dev wrote:
>>>> Using list with /vsicurl only returns results if I specify a file. No
>>>> results when specifying a directory. /vsis3 works as expected. Am I
>>>> doing this correctly?
>>>> Works:
>>>> gdal vsi list -lR
>>>> "/vsicurl/https://cdn.star.nesdis.noaa.gov/GOES18/ABI/MESO/M1/GEOCOLOR/2025292000425_GOES18-ABI-MESO-GEOCOLOR-39N-119W-1000x1000.jpg"
>>>> No workee:
>>>> gdal vsi list -lR
>>>> /vsicurl_streaming only returns directory name:
>>>> gdal vsi list -lR
>>>> "/vsicurl_streaming/https://cdn.star.nesdis.noaa.gov/GOES18/ABI/MESO/M1/GEOCOLOR/"
>>>> --depth has no effect.
>>>> Debian 12/GDAL 3.12.0beta1
>>>> Thanks!
>>>> Scott
>>>> www.postholer.com
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
