[gdal-dev] Proper usage of gdal vsi list
Laurențiu Nicola
lnicola at dend.ro
Tue Oct 28 12:11:51 PDT 2025
I think GDAL doesn't parse it because the URL doesn't match the directory name on the page (/ma-cdn03/GOES/data/GOES18/ABI/MESO/M1/GEOCOLOR/).
On Tue, Oct 28, 2025, at 20:58, Scott via gdal-dev wrote:
> Thanks for that! The sites you listed worked will with the gdal vsi list
> client.
> Interestingly, the following worked with your sites as well, but not the
> NOAA site:
> wget --spider -r --no-parent
> https://cdn.star.nesdis.noaa.gov/GOES19/ABI/MESO/18N-76W/GEOCOLOR/ 2>&1
> | grep "^--"
> On 10/28/25 11:44, Laurențiu Nicola via gdal-dev wrote:
>> I was wrong, GDAL actually has code to deal with the autoindex pages: https://github.com/OSGeo/gdal/blob/0f757d0/port/cpl_vsil_curl.cpp#L5024-L5340. It just doesn't work very well with your site:
>>>>> gdal.ReadDir("/vsicurl/https://cscie12.dce.harvard.edu/apache/autoindex/")
>> ['client-server.gif', 'raspberry.gif', 'raspberry.jpg', 'raspberry.png', 'slide1.html', 'slide2.html', 'slide3.html']
>>>>> gdal.ReadDir("/vsicurl/https://nginx.org/packages/")
>> ['aix', 'alpine', 'amzn', 'centos', 'debian', 'keys', 'rhel', 'sles', 'ubuntu', 'mainline']
>>>>> gdal.ReadDir("/vsicurl/https://cdn.star.nesdis.noaa.gov/GOES18/ABI/MESO/M1/GEOCOLOR/")
>> (nothing)
>> Laurentiu
>> On Tue, Oct 28, 2025, at 20:31, Scott via gdal-dev wrote:
>>> But, the docs say:
>>> gdal vsi list list files of GDAL Virtual File Systems (compressed,
>>> network hosted, etc...): /vsimem, /vsizip, /vsitar, /vsicurl, ....
>>> ...so this implies http dir listings via /vsicurl. I may be interpreting
>>> that incorrectly, though.
>>> Scott
>>> On 10/28/25 11:17, Laurențiu Nicola via gdal-dev wrote:
>>>> I'd be quite surprised if GDAL's vsicurl was able to understand a directory index.
>>>> Take https://cscie12.dce.harvard.edu/apache/autoindex/, for example, it's clear that's a directory with 7 files, but it also has a bunch of column sorting links you'd want to ignore.
>>>> To be fair, there aren't that many directory index formats, but I'm not sure that parsing them is a job for GDAL.
>>>> Laurentiu
>>>> On Tue, Oct 28, 2025, at 18:28, Scott via gdal-dev wrote:
>>>>> Using list with /vsicurl only returns results if I specify a file. No
>>>>> results when specifying a directory. /vsis3 works as expected. Am I
>>>>> doing this correctly?
>>>>> Works:
>>>>> gdal vsi list -lR
>>>>> "/vsicurl/https://cdn.star.nesdis.noaa.gov/GOES18/ABI/MESO/M1/GEOCOLOR/2025292000425_GOES18-ABI-MESO-GEOCOLOR-39N-119W-1000x1000.jpg"
>>>>> No workee:
>>>>> gdal vsi list -lR
>>>>> /vsicurl_streaming only returns directory name:
>>>>> gdal vsi list -lR
>>>>> "/vsicurl_streaming/https://cdn.star.nesdis.noaa.gov/GOES18/ABI/MESO/M1/GEOCOLOR/"
>>>>> --depth has no effect.
>>>>> Debian 12/GDAL 3.12.0beta1
>>>>> Thanks!
>>>>> Scott
>>>>> www.postholer.com
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
