[gdal-dev] gdal raster clip - need some help
Even Rouault even.rouault at spatialys.com
Wed Sep 17 12:49:14 PDT 2025
Hi Scott,
please file a GH issue about that. The PGRaster indeed kicks in here.
gdalwarp doesn't have that issue as it only uses vector drivers for the
cutline whereas gdal raster clip allows both raster & vector drivers. In
the mean time you should be able to work around the issue by adding
"--config GDAL_SKIP=PostGISRaster"
Even
Le 17/09/2025 à 20:06, Scott via gdal-dev a écrit :
> I'm trying to clip a raster with a vector data source:
> gdal raster clip \
>    --input=raster.tif \
>    --like="PG:dbname=mydb" --like-sql="select geom from vector_table" \
>    --output=clipped.tif --overwrite --progress
> It gives me the error:
> ERROR 1: clip: Cannot get extent from clip dataset
> If I use a .gpkg in --like, it works fine.
> gdalwarp works fine with the same raster and same PG vector table:
> gdalwarp -cutline PG:dbname=mydb -csql "select geom from vector_table"
> raster.tif clipped.tif
> If I modify the connection string to:
> --like="PG:mydb table=vector_table"
> It seems to think it's a raster table:
> Creating tile for bbox -12980000,3850000,-12970000,3860000
> Warning 1: Cannot find information about public.vector_table table in
> raster_columns view. The raster table load would take a lot of time.
> Please, execute AddRasterConstraints PostGIS function to register this
> table as raster table in raster_columns view. This will save a lot of
> time.
> ERROR 1: Error browsing database for PostGIS Raster properties :
> ERROR: column "rast" does not exist
> LINE 1: ...m) as ymax, scale_x, scale_y from (select st_srid("rast")
> sr...
> Am I missing a key parameter here?
> Debian 12, GDAL 3.11.3
> Thanks!
> Scott
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
