[gdal-dev] gdal raster clip - need some help
    Scott
    public at postholer.com
    Wed Sep 17 13:17:25 PDT 2025
Thanks Even, worked great! Issue has been submitted.
Scott
On 9/17/25 12:49, Even Rouault wrote:
> Hi Scott,
> please file a GH issue about that. The PGRaster indeed kicks in here.
> gdalwarp doesn't have that issue as it only uses vector drivers for the
> cutline whereas gdal raster clip allows both raster & vector drivers. In
> the mean time you should be able to work around the issue by adding "--
> config GDAL_SKIP=PostGISRaster"
> Even
> Le 17/09/2025 à 20:06, Scott via gdal-dev a écrit :
>> I'm trying to clip a raster with a vector data source:
>> gdal raster clip \
>>    --input=raster.tif \
>>    --like="PG:dbname=mydb" --like-sql="select geom from vector_table" \
>>    --output=clipped.tif --overwrite --progress
>> It gives me the error:
>> ERROR 1: clip: Cannot get extent from clip dataset
>> If I use a .gpkg in --like, it works fine.
>> gdalwarp works fine with the same raster and same PG vector table:
>> gdalwarp -cutline PG:dbname=mydb -csql "select geom from vector_table"
>> raster.tif clipped.tif
>> If I modify the connection string to:
>> --like="PG:mydb table=vector_table"
>> It seems to think it's a raster table:
>> Creating tile for bbox -12980000,3850000,-12970000,3860000
>> Warning 1: Cannot find information about public.vector_table table in
>> raster_columns view. The raster table load would take a lot of time.
>> Please, execute AddRasterConstraints PostGIS function to register this
>> table as raster table in raster_columns view. This will save a lot of
>> time.
>> ERROR 1: Error browsing database for PostGIS Raster properties :
>> ERROR: column "rast" does not exist
>> LINE 1: ...m) as ymax, scale_x, scale_y from (select st_srid("rast")
>> sr...
>> Am I missing a key parameter here?
>> Debian 12, GDAL 3.11.3
>> Thanks!
>> Scott
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
