[gdal-dev] GDAL NMAKE fatal error U1077
    Mazin Marwan
    mazin.marwan0 at gmail.com
    Mon Sep 22 08:48:47 PDT 2025
Hello,
I'm running into the following error while attempting to build gdal 2.4.4
C:\build\drdc\gdal\gdal-2.4.4\frmts>cd mrsid   && nmake /nologo /f
makefile.vc   && cd ..   || exit 1
        cl   /nologo /MP /MD /EHsc /Ox /FC /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /W4 /wd4127 /wd4251 /wd4275 /wd4786
/wd4100 /wd4245 /wd4206 /wd4351 /wd4611  /DHAVE_SSE_AT_COMPILE_TIME
/DHAVE_SSSE3_AT_COMPILE_TIME -I..\..\port -I..\..\ogr -I..\..\gcore
-I..\..\alg -I..\..\ogr\ogrsf_frmts  -I..\..\gnm -I..\..\gnm\gnm_frmts
-I..\..\apps /DHAVE_AVX_AT_COMPILE_TIME
-I"C:\build\drdc\3rdparty\x64\MrSID_DSDK-9.5.4.5047-win64-vc16\Lidar_DSDK\include"
-I"C:\build\drdc\3rdparty\x64\MrSID_DSDK-9.5.4.5047-win64-vc16\Raster_DSDK\include"
-I..\gtiff\libgeotiff -DMRSID_LVER=111 -DMRSID_RVER=800 -DMRSID_J2K
 -DGNM_ENABLED  -DGDAL_COMPILATION -DNOMINMAX /c mrsiddataset.cpp
mrsidstream.cpp
mrsiddataset.cpp
mrsidstream.cpp
C:\build\drdc\3rdparty\x64\MrSID_DSDK-9.5.4.5047-win64-vc16\Raster_DSDK\include\lt_platform.h(101):
fatal error C1189: #error:  PLATFORM ERROR: unknown compiler (compiling
source file mrsidstream.cpp)
source file mrsiddataset.cpp)
NMAKE : fatal error U1077: 'cl   /nologo /MP /MD /EHsc /Ox /FC
/D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /W4 /wd4127
/wd4251 /wd4275 /wd4786 /wd4100 /wd4245 /wd4206 /wd4351 /wd4611
/DHAVE_SSE_AT_COMPILE_TIME /DHAVE_SSSE3_AT_COMPILE_TIME -I..\..\port
-I..\..\ogr -I..\..\gcore  -I..\..\alg -I..\..\ogr\ogrsf_frmts  -I..\..\gnm
-I..\..\gnm\gnm_frmts -I..\..\apps /DHAVE_AVX_AT_COMPILE_TIME
mrsidstream.cpp ' : return code '0x2'
Stop.
NMAKE : fatal error U1077: 'for %d in ( jpeg ceos aigrid elas hfa gtiff
sdts raw gxf ceos2 png  dted mem jdem gif  envisat aaigrid usgsdem l1b  fit
vrt xpm bmp rmf  nitf pcidsk airsar rs2 rcm  ilwis msgn rik pcraster
leveller sgi srtmhgt idrisi  jaxapalsar ers ingr dimap  gff terragen gsg
cosar pds  adrg coasp tsx blx til  r northwood saga xyz hf2
kmlsuperoverlay ozi ctg e00grid  zmap ngsgeoid iris map cals  safe
sentinel2 derived prf  sigdem ignfheightasciigrid postgisraster bsb
jpeg2000 ecw hdf4 hdf5 mrsid mrsid_lidar pdf netcdf grib wcs wms plmosaic
wmts rda eeda arg mrf ) do  cd %d  && nmake /nologo /f makefile.vc  && cd
..  || exit 1' : return code '0x1'
Stop.
NMAKE : fatal error U1077: 'nmake /nologo /f makefile.vc' : return code
'0x2'
Stop.
This is happening when I run nmake -f makefile.vc MSVC_VER=1929 WIN64=1
I'm running this on Windows 11, off of "x64 Native Tools Command Prompt for
VS 2022"
Is anyone aware of what the platform error is and how to solve it?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250922/85a8dea6/attachment-0001.htm>
