[gdal-dev] GDAL NMAKE fatal error U1077
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Sep 22 10:27:31 PDT 2025
Hi Mazin,
It looks like you are trying to point to the v16 (VC 2019) version of
the MrSID SDK, but your local compiler is v17 (VC 2022).
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2025-09-22 12:48 p.m., Mazin Marwan via gdal-dev wrote:
> Hello,
> I'm running into the following error while attempting to build gdal 2.4.4
> C:\build\drdc\gdal\gdal-2.4.4\frmts>cd mrsid   && nmake /nologo /f
> makefile.vc <http://makefile.vc>   && cd ..   || exit 1
>          cl   /nologo /MP /MD /EHsc /Ox /FC /D_CRT_SECURE_NO_DEPRECATE /
> D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /W4 /wd4127 /wd4251 /wd4275 /
> wd4786 /wd4100 /wd4245 /wd4206 /wd4351 /wd4611  /
> DHAVE_SSE_AT_COMPILE_TIME /DHAVE_SSSE3_AT_COMPILE_TIME -I..\..\port -I..
> \..\ogr -I..\..\gcore  -I..\..\alg -I..\..\ogr\ogrsf_frmts  -I..\..\gnm
> -I..\..\gnm\gnm_frmts -I..\..\apps /DHAVE_AVX_AT_COMPILE_TIME -I"C:
> \build\drdc\3rdparty\x64\MrSID_DSDK-9.5.4.5047-win64-
> vc16\Lidar_DSDK\include" -I"C:
> vc16\Raster_DSDK\include"  -I..\gtiff\libgeotiff -DMRSID_LVER=111 -
> DMRSID_RVER=800 -DMRSID_J2K   -DGNM_ENABLED  -DGDAL_COMPILATION -
> DNOMINMAX /c mrsiddataset.cpp mrsidstream.cpp
> mrsiddataset.cpp
> mrsidstream.cpp
> C:\build\drdc\3rdparty\x64\MrSID_DSDK-9.5.4.5047-win64-
> vc16\Raster_DSDK\include\lt_platform.h(101): fatal error C1189: #error:
> PLATFORM ERROR: unknown compiler (compiling source file mrsidstream.cpp)
> PLATFORM ERROR: unknown compiler (compiling source file mrsiddataset.cpp)
> NMAKE : fatal error U1077: 'cl   /nologo /MP /MD /EHsc /Ox /FC /
> D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /W4 /
> wd4127 /wd4251 /wd4275 /wd4786 /wd4100 /wd4245 /wd4206 /wd4351 /
> wd4611  /DHAVE_SSE_AT_COMPILE_TIME /DHAVE_SSSE3_AT_COMPILE_TIME -I..\..
> \port -I..\..\ogr -I..\..\gcore  -I..\..\alg -I..\..\ogr\ogrsf_frmts  -
> I..\..\gnm -I..\..\gnm\gnm_frmts -I..\..\apps /DHAVE_AVX_AT_COMPILE_TIME
> -I"C:\build\drdc\3rdparty\x64\MrSID_DSDK-9.5.4.5047-win64-
> DNOMINMAX /c mrsiddataset.cpp mrsidstream.cpp ' : return code '0x2'
> Stop.
> NMAKE : fatal error U1077: 'for %d in ( jpeg ceos aigrid elas hfa gtiff
> sdts raw gxf ceos2 png  dted mem jdem gif  envisat aaigrid usgsdem l1b
> fit vrt xpm bmp rmf  nitf pcidsk airsar rs2 rcm  ilwis msgn rik
> pcraster  leveller sgi srtmhgt idrisi  jaxapalsar ers ingr dimap  gff
> terragen gsg cosar pds  adrg coasp tsx blx til  r northwood saga xyz
> hf2  kmlsuperoverlay ozi ctg e00grid  zmap ngsgeoid iris map cals  safe
> sentinel2 derived prf  sigdem ignfheightasciigrid postgisraster bsb
> jpeg2000 ecw hdf4 hdf5 mrsid mrsid_lidar pdf netcdf grib wcs wms
> plmosaic wmts rda eeda arg mrf ) do  cd %d  && nmake /nologo /f
> makefile.vc <http://makefile.vc>  && cd ..  || exit 1' : return code '0x1'
> Stop.
> NMAKE : fatal error U1077: 'nmake /nologo /f makefile.vc <http://
> makefile.vc>' : return code '0x2'
> Stop.
> This is happening when I run nmake -f makefile.vc <http://makefile.vc>
> MSVC_VER=1929 WIN64=1
> I'm running this on Windows 11, off of "x64 Native Tools Command Prompt
> for VS 2022"
> Is anyone aware of what the platform error is and how to solve it?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
