[gdal-dev] GeoTIFF in South Africa
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Sep 25 08:24:12 PDT 2025
Hi
I got a GeoTIFF from South Africa that is displayed in the Mediterranean
sea in QGIS.
$ gdalinfo sa.tif
Driver: GTiff/GeoTIFF
Files: sa.tif
Size is 1305, 909
Coordinate System is:
PROJCRS["Hartebeesthoek94 / Lo21",
    BASEGEOGCRS["Hartebeesthoek94",
    ID["EPSG",2049]]
Data axis to CRS axis mapping: 1,2
Origin = (-43632.855010000006587,-3629566.022050000261515)
Pixel Size = (0.275826758620690,-0.275760660066007)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_SOFTWARE=pix4dmapper
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
  PREDICTOR=2
As you can see, the Origin is very negative, and in Lo21 it should be
positive.
Ok, lets change the geotransform parameters:
$ gdal_translate -a_gt 43632.8550100000 -0.275760660 0 3629566.0220500 0
0.27576066 -co COMPRESS=LZW -co PREDICTOR=2 sa.tif sa.located.tif
$ gdalinfo sa.located.tif
Files: sa.located.tif
Size is 1305, 909
        DATUM["Hartebeesthoek94",
    ID["EPSG",2049]]
Origin = (43632.855009999999311,3629566.022049999795854)
Pixel Size = (-0.275760660000000,0.275760660000000)
That appears properly located in QGIS. But I think that due to the signs in
the pixel size, it is performing really bad (it is not doing some
optimizations)
I run gdalwarp hoping that it changes it. And it does in GDAL 3.8.4
$ gdalinfo --version
GDAL 3.8.4, released 2024/02/08
$ gdalwarp sa.located.tif sa.cog.3.8.4.tif -of COG
$ gdalinfo sa.cog.3.8.4.tif
Files: sa.cog.3.8.4.tif
Size is 1305, 909
    ID["EPSG",2049]]
Origin = (43272.987348700000439,3629816.688489940017462)
Pixel Size = (0.275760660000079,-0.275760660000079)
See how it changes the origin and the signs of the pixel size
However in 3.11.4 it is different
$ gdalinfo sa.cog.3.11.4.tif
Files: sa.cog.3.11.4.tif
Size is 1305, 909
    ID["EPSG",2049]]
Origin = (43632.855009999999311,3629816.688489940017462)
Pixel Size = (-0.275760660000000,-0.275760660000000)
Having the negative pixel size for the first coordinate is affecting the
performance in QGIS?
Is there a better way to do all this?
Thank you,
Javier
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250925/0de87051/attachment.htm>
