[gdal-dev] GeoTIFF in South Africa
Even Rouault
even.rouault at spatialys.com
Thu Sep 25 08:50:32 PDT 2025
Javier,
can you post the output of "listgeo sa.tif" (on the original GeoTIFF) ?
It would be interesting to see if they correctly use the
CT_TransvMercator_SouthOrientated ProjCoordTransGeoKey
I don't remember a change that would explicily try to respect the
negative sign of the x-pixelsize parameter in gdalwarp as those are
rather untypical, but it might be a side effect of other changes. For
those untypical geotransforms, QGIS will use GDAL's AutoWarpVRT
functionality, which indeed has a runtime cost.
You may generate a "correctly" oriented file by specifying explicit -te
to gdalwarp
Even
Le 25/09/2025 à 17:24, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> I got a GeoTIFF from South Africa that is displayed in the
> Mediterranean sea in QGIS.
> $ gdalinfo sa.tif
> Driver: GTiff/GeoTIFF
> Files: sa.tif
> Size is 1305, 909
> Coordinate System is:
> PROJCRS["Hartebeesthoek94 / Lo21",
> BASEGEOGCRS["Hartebeesthoek94",
> ID["EPSG",2049]]
> Data axis to CRS axis mapping: 1,2
> Origin = (-43632.855010000006587,-3629566.022050000261515)
> Pixel Size = (0.275826758620690,-0.275760660066007)
> Metadata:
> AREA_OR_POINT=Area
> TIFFTAG_SOFTWARE=pix4dmapper
> Image Structure Metadata:
> COMPRESSION=LZW
> INTERLEAVE=PIXEL
> PREDICTOR=2
> As you can see, the Origin is very negative, and in Lo21 it should be
> positive.
> Ok, lets change the geotransform parameters:
> $ gdal_translate -a_gt 43632.8550100000 -0.275760660 0 3629566.0220500
> 0 0.27576066 -co COMPRESS=LZW -co PREDICTOR=2 sa.tif sa.located.tif
> $ gdalinfo sa.located.tif
> Files: sa.located.tif
> Size is 1305, 909
> DATUM["Hartebeesthoek94",
> ID["EPSG",2049]]
> Origin = (43632.855009999999311,3629566.022049999795854)
> Pixel Size = (-0.275760660000000,0.275760660000000)
> That appears properly located in QGIS. But I think that due to the
> signs in the pixel size, it is performing really bad (it is not doing
> some optimizations)
> I run gdalwarp hoping that it changes it. And it does in GDAL 3.8.4
> $ gdalinfo --version
> GDAL 3.8.4, released 2024/02/08
> $ gdalwarp sa.located.tif sa.cog.3.8.4.tif -of COG
> $ gdalinfo sa.cog.3.8.4.tif
> Files: sa.cog.3.8.4.tif
> Size is 1305, 909
> ID["EPSG",2049]]
> Origin = (43272.987348700000439,3629816.688489940017462)
> Pixel Size = (0.275760660000079,-0.275760660000079)
> See how it changes the origin and the signs of the pixel size
> However in 3.11.4 it is different
> $ gdalinfo sa.cog.3.11.4.tif
> Files: sa.cog.3.11.4.tif
> Size is 1305, 909
> ID["EPSG",2049]]
> Origin = (43632.855009999999311,3629816.688489940017462)
> Pixel Size = (-0.275760660000000,-0.275760660000000)
> Having the negative pixel size for the first coordinate is affecting
> the performance in QGIS?
> Is there a better way to do all this?
> Thank you,
> Javier
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250925/ce3d122d/attachment.htm>
