[gdal-dev] Anyone has already forgotten the /vsicurl/ prefix?
Even Rouault
even.rouault at spatialys.com
Sat Apr 4 09:01:10 PDT 2026
Following-up on this, after a bit of not super conclusive
experimentation, I gave up on the idea of a GDAL autoselection of HTTP
driver vs /vsicurl/ . The sad reality is that the web in 2026 is not yet
ready for GDAL very demanding expectations, i.e. that servers in the
wild would return reliably & fastly a "Accept-range: none" or
"Accept-range: bytes" header to a HEAD request.
So I've fallen back to documenting that whole issue in
https://github.com/OSGeo/gdal/pull/14291
Even
Le 27/03/2026 à 18:08, Even Rouault via gdal-dev a écrit :
> Hi,
> I suspect that almost every GDAL user, even the most experienced, has
> made the mistake of typing "gdalinfo https://example.com/my.tif"
> instead of "gdalinfo /vsicurl/https://example.com/my.tif". Both
> commands work, but the first one triggers the HTTP pseudo-driver which
> downloads the entire file into memory before passing it to the GeoTIFF
> driver, while the second reads it in chunks.
> I would be inclined to modify the GDALOpen() logic with the following
> tweak: if the passed filename starts with "http://" or "https://",
> automatically prepend "/vsicurl/", unless the string has query
> parameters. That restriction about not having query parameters is
> because in most of the cases this is for dynamically generated
> resources that don't support range requests.
> For users really wanting to go through the HTTP pseudo-driver, we'd
> modify it to accept a "HTTP:" prefix before the URL or it would
> trigger if using the "-if HTTP" argument of command line utilities (or
> allowed_drivers = ["HTTP"] in the API)
> So this change wouldn't be fully backwards compatible, but I feel it
> would still make more people happy than unhappy.
> Thoughts?
> Even
http://www.spatialys.com
