[gdal-dev] inconsistent naming for the CLI "input" argument
Even Rouault
even.rouault at spatialys.com
Sun Apr 5 14:16:45 PDT 2026
Hopefully your below suggestions are captured in
https://github.com/OSGeo/gdal/pull/14297
Thanks for the analysis. Consistency is hard!
Even
Le 05/04/2026 à 20:22, Chris Toney a écrit :
> Even,
> Thanks for the comments. That helps a lot, if I understand correctly now:
> "input" alone - not modified
> "dataset" alone - modified / is input and output
> "input" with "dataset" alias - the input may be modified
> Going back through with that in mind, it looks largely consistent with
> a small number of exceptions. Starting with "raster edit", it has only
> "dataset" which is input and output, then...
> "raster info"
> -i, --dataset, --input <INPUT>
> Makes sense, input may be modified, e.g., if --stats are computed they
> may be set back on the input dataset.
> "vector info"
> Same, input may be modified if --sql is given for UPDATE, DELETE, etc.
> Exceptions:
> "vector sql"
> -i, --input <INPUT>
> Should also have "dataset" alias?
>> Starting with GDAL 3.12, when using --update, and without an output dataset specified, this can be used to execute statements that modify the input dataset, such as UPDATE, DELETE, etc.
> "gdal info"
> -i, --input <INPUT>
> Add "dataset" alias to align with "raster info" and "vector info"?
> (and "mdim info" also has "dataset" alias)
> Then these three probably should be aligned:
> "raster overview add"
> -i, --dataset, --input <INPUT> Dataset (to be updated in-place,
> unless --external)
> "raster overview delete"
> --dataset <DATASET> Dataset (to be updated in-place, unless --read-only)
> "raster overview refresh"
> --dataset <DATASET> Dataset (to be updated in-place, unless --external)
> This one has "dataset" alias but does not modify input, seems to be a
> lone exception in that regard:
> "raster update"
> -o, --output <OUTPUT>
> I think "dataset" should be kept based on that understanding.
> I don't have strong feelings on the <meta_var> names other than
> consistency is good. The existing "inconsistencies" are pretty minor
> so not sure if changes are really needed.
> The aim is not to be super nitpicky over arg names and their aliases.
> Motivation is API usage where application code takes dataset objects
> as user input to CLI algorithms. The dataset objects may carry
> information that should be used to parameterize the algorithm call.
> The user may have already set properties on the object and should not
> have to provide those explicitly again when passing to an algorithm.
> The algorithm arg names must be used in parsing in some cases to infer
> meaning, i.e., we cannot always rely only on querying properties of
> the AlgorithmArg object. An example is "like" / "like-layer" /
> "like-sql" / "like-where". Parsing for those needs to rely on the arg
> names (and any potential aliases) for meaning. So the names/aliases
> really should be always consistent, which I believe they are in that
> case.
> "input" and "dataset" aren't quite the same since we can query the
> AlgorithmArg object and determine what it's for. But the more
> consistent they can be in usage the better IMO.
> Chris
> On Sun, Apr 5, 2026 at 4:21 AM Even Rouault <even.rouault at spatialys.com> wrote:
>> Hi Chris,
>>> The main issue is the occasional use of "dataset" as an alias for
>>> "input". It's inconsistently available as an alias which seems not
>>> ideal, but it also shows up in unexpected ways.
>>> "raster edit" has only --dataset with no --input or -i:
>>> --dataset <DATASET>
>> The rationale was that raster edit only takes a single dataset which is
>> both input and output. Input could also suggest that it won't be
>> modified, which is not the case here. But I see we have hesitated in
>> different similar (or similar looking, but subtely different) situations
>> if we needed to expose input, dataset or both.
>>> "raster overview add" has:
>>> But "raster overview delete" and "raster overview refresh" have only:
>>> --dataset <DATASET>
>>> A dataset-specific one "dataset check" doesn't use it:
>>> -i, --input <INPUT>
>> For dataset check, the dataset isn't modified.
>>> Is the "dataset" alias really worth having?
>> Good question. Happy to hear about other's opinion on this.
>>> A couple others are unique cases that may not be a problem. These just
>>> stand out as different since meta_var rarely deviates from the naming
>>> pattern.
>>> "raster calc" has:
>>> -i, --input <INPUTS>
>> Plural to suggest you can specify several ones
>>> "raster blend" has:
>>> -i, --color-input, --input <COLOR-INPUT>
>> The metavar is important to remind the semantics because it accepts a
>> second input dataset : --overlay <OVERLAY>
>>> Those are the only cases I've found where the meta_var name is
>>> different than the long name. Nearly all have <INPUT> for --input even
>>> if there is an alias, e.g., "raster pansharpen" has `-i,
>>> --panchromatic, --input <INPUT>`.
>> Similar to raster blend:
>> -i, --panchromatic, --input <INPUT> Input panchromatic raster dataset
>> [required]
>> --spectral <SPECTRAL> Input spectral band dataset [1.. values] [required]
>> The input name helps here to remember which dataset is implicit or not
>> when you use it in a pipeline context (input must not be specified as
>> the result of the previous step):
>> gdal raster pipeline read panchro.tif ! pansharpen multispectral.tif !
>> write out.tif
>>> I checked several others that can
>>> take multiple input datasets, and "raster calc" is the only one I
>>> found with plural INPUTS. Maybe that's not a big deal because the
>>> meta_var is only for display in the documentation? It could still be
>>> worth making them consistent for readability.
>> Yes we could put plural INPUTS in other situations where input accepts
>> multiple files
>>> Since <INPUT> is almost
>>> always used for the positional input dataset(s), when I see
>>> <COLOR-INPUT> it looks like possibly something other than a raster
>>> dataset.
>> Should the metavar of INPUT be INPUT-DATASET in general case, and
>> COLOR-INPUT-DATASET for blend / PANCHRO-DATASET for pansharpen ?
>> http://www.spatialys.com
>> My software is free, but my time generally not.
