[gdal-dev] inconsistent naming for the CLI "input" argument
Andrew C Aitchison gdal at aitchison.me.uk
Sun Apr 5 07:47:40 PDT 2026
  On Sun, 5 Apr 2026, Chris Toney via gdal-dev wrote:
> A large majority of the CLI algorithms use `-i, --input
> <INPUT>` for
> the input arg, and those are the names generally described
> in
> specifications. There is a lot of variation though. I'm not
> suggesting
> they should all be made entirely consistent. Various
> aliases make
> sense to have in some cases. But several cases seem worth
> considering.
> The main issue is the occasional use of "dataset" as an
> alias for
> "input". It's inconsistently available as an alias which
> seems not
> ideal, but it also shows up in unexpected ways.
> "raster edit" has only --dataset with no --input or -i:
> --dataset <DATASET>
> "raster overview add" has:
> -i, --dataset, --input <INPUT>
> But "raster overview delete" and "raster overview refresh"
> have only:
> --dataset <DATASET>
> A dataset-specific one "dataset check" doesn't use it:
> -i, --input <INPUT>
> Is the "dataset" alias really worth having?
  For 'raster edit' and 'raster delete' I don't see --input as
appropriate (although logically raster delete --input is not
wrong).
Andrew C. Aitchison                      Kendal, UK
                    andrew at aitchison.me.uk
