[gdal-dev] Parquet error/warning on large list columns
Michael Smith michael.smith.erdc at gmail.com
Sat Apr 11 06:20:02 PDT 2026
In our stac geoparquet files, we are getting warning/errors (depending on cli vs python) on unhandled type:large list
Warning 1: Field proj.shape of unhandled type large_list<element: int64> ignored
Warning 1: Field stac_extensions of unhandled type large_list<element: large_string> ignored
Or
GDAL_ERROR 1: b'Field stac_extensions of unhandled type large_list<element: large_string> ignored'
I’m using polars and pyogrio (polars-st) to write the data and the schema is defined as
extensionschema = pl.List(pl.Utf8)
proj.shape = pl.List(pl.Int64)
The columns are not reported in the column list and are not present when converting the data to another parquet file.
This is GDAL 3.12.3 "Chicoutimi", released 2026/03/17 installed via conda forge.
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260411/aea2875b/attachment.htm>
