[gdal-dev] Parquet error/warning on large list columns
Even Rouault
even.rouault at spatialys.com
Sat Apr 11 06:56:38 PDT 2026
Hi Mike,
fix in https://github.com/OSGeo/gdal/pull/14326
Even
Le 11/04/2026 à 15:20, Michael Smith via gdal-dev a écrit :
> In our stac geoparquet files, we are getting warning/errors (depending
> on cli vs python) on unhandled type:large list
> Warning 1: Field proj.shape of unhandled type large_list<element:
> int64> ignored
> Warning 1: Field stac_extensions of unhandled type large_list<element:
> large_string> ignored
> Or
> GDAL_ERROR 1: b'Field stac_extensions of unhandled type
> large_list<element: large_string> ignored'
> I’m using polars and pyogrio (polars-st) to write the data and the
> schema is defined as
> extensionschema = pl.List(pl.Utf8)
> proj.shape = pl.List(pl.Int64)
> The columns are not reported in the column list and are not present
> when converting the data to another parquet file.
> This is GDAL 3.12.3 "Chicoutimi", released 2026/03/17 installed via
> conda forge.
> Michael Smith
> RSGIS Center – ERDC CRREL NH
> US Army Corps
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260411/423d723e/attachment.htm>
