[gdal-dev] AI/LLM tool policy: failure
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Apr 13 02:46:16 PDT 2026
Thanks Even.
I found the previous AI policy too naïve. I am totally fine with a much
more strict policy.
As you and other people explained, the situation PR-producer vs reviewer is
completely unbalanced with AI.
Cheers
Javier
On Sun, 12 Apr 2026 at 21:49, Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> It was nice trying but I believe we can close the experiment as a
> failure. At least I personally cannot deal with the mental consequences
> in term of reviewing. To make it short, I believe humans aren't designed
> to be at the receiving end of LLM generated content. This is a too
> unnatural relationship. More details in this thread:
> https://lists.osgeo.org/pipermail/qgis-developer/2026-April/068204.html
> So what to do now... ? Personally I believe I'll give up on reviewing
> LLM generated PRs. If there are other devs with merge rights who want to
> give them a try, please raise your arm. Otherwise, if there are not,
> we'll have to revise the policy to better reflect our wishes and abilities.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260413/e276765e/attachment-0001.htm>
