[QGIS-Developer] Floating an idea: ban AI based contributed from non-core developers?
Even Rouault even.rouault at spatialys.com
Sun Apr 12 12:38:04 PDT 2026
> One key point here. It is really **hard** to decrypt the quality of
> LLM generated code, because it is trained to be plausible.
I triple on that. I've always found that (in depth) reviewing was a task
consuming a lot of mental energy, often more than coding, but in pre-LLM
times, you knew that the contributor had already invested a lot of
energy into creating their submission, so that made your own energy
investment acceptable. Now, the reviewer is mostly the only one that
sweats.  When you make comments and get a reply, you never know if the
reply comes from the human, the machine or a mix of them. This is really
really really unpleasant.  In our highly decentralized community, the
lack of direct interaction pre-LLM could also be a challenge (mechanisms
behind the working of human psychology have been forged by natural
selection over ~ 3 million years of face-to-face interactions, add tens
of extra millions years inherited from our closest cousins in the animal
reign, compared to hardly 50 years of digital communication), but at
least you knew that at @someone was a peer.  Now you don't know anymore.
You're becoming effectively the slave of an agent.
Among the things I dislike is the wall'o'text LLM generated PR
descriptions. I believe we should ban them and require contributors to
come with their own succinct and to-the-point descriptions. Or if they
can't come up with one, just none. That makes at least less stuff to
review!  But then the "human in the loop" policy no longer works.
Maybe we should charge a symbolic fee to new contributors for each PR
they submit, until one is accepted? I bet this would make them think
twice. Unfortunately that's not a github feature.
>  Knowing this, a friendly contributor, willing to getting involved in
> the long term, and who will use AI as a helper for its first
> contributions, should know that it will put a very high charge on
> reviewers. So this is like a poisoned gift.
One difficulty is that it is likely really hard for someone not having
already experienced themselves reviewing LLM generated PRs to know how
it feels to deal with them.
Writing all the above with https://github.com/qgis/QGIS/pull/65778 in
mind. Took me maybe one hour of digging (yes not fast but CMake is full
of subtelties) to realize that there is (likely) a much simpler fix than
the one suggested (I may be wrong, let's see what the bot answers). I
believe that 6 months ago I would have approved the exact same PR
content without much thinking. So one could argue that the extra
skepticism when confronting to LLM generated PR is a good thing, but
frankly it is exhausting. I believe there's a new job lurking: "mental
coach/psychologist for developers dealing with LLM contributions"
http://www.spatialys.com
More information about the QGIS-Developer mailing list
