[gdal-dev] ExportToGML with compound CRS
Even Rouault even.rouault at spatialys.com
Wed Apr 15 08:25:02 PDT 2026
no other workaround but applying
https://github.com/OSGeo/gdal/pull/14367 (or post patching the output)
Even
Le 15/04/2026 à 16:53, Joep Keijsers via gdal-dev a écrit :
> Greetings,
> I'm trying to export a geometry object to GML using the Python API. The geometry has a compound CRS (EPSG:5973). When exporting to GML, the vertical component of the compound CRS is dropped, although the Z-values are still there. For example:
> from osgeo import ogr, osr
> # Create geometry from WKT string
> srs = osr.SpatialReference()
> srs.ImportFromEPSG(5973)
> wkt = "POINT (30 10 5)"
> geometry = ogr.CreateGeometryFromWkt(wkt, srs)
> # Export to GML
> xml = geometry.ExportToGML(options=['FORMAT=GML32', 'SRSDIMENSION_LOC=GEOMETRY', 'SRSNAME_FORMAT=SHORT', 'GMLID=TestPoint-1'])
> print(xml)
> ... which returns EPSG:11023 instead of EPSG:5973:
> <gml:Point srsName="EPSG:11023" srsDimension="3" gml:id="TestPoint-1"><gml:pos>30 10 5</gml:pos></gml:Point>
> I believe this EPSG code change happens in this line: https://github.com/OSGeo/gdal/blob/30e7918f245022983d84f93f1a53641fd50337ed/ogr/ogr2gmlgeometry.cpp#L562.
> Is there a way to keep the compound CRS in the GML output?
> Version info: gdal 3.12.3
> Thanks!
> Joep
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
