[gdal-dev] ExportToGML with compound CRS
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Wed Apr 15 08:28:41 PDT 2026
Hi
Even made a fix already but here is a command for testing with the old school CLI.
ogr2ogr -f gml -a_srs EPSG:5973 compound.gml :memory: -sql "select 1 as id, st_geomfromtext('POINTZ (1 1 1)') as geom" -nln test
"boundedBy" seems to receive
srsName="urn:ogc:def:crs:EPSG::5973 but the geometry itself srsName="urn:ogc:def:crs:EPSG::11023"
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
Lähetetty: Keskiviikko 15. huhtikuuta 2026 18.25
Vastaanottaja: Joep Keijsers <joep.keijsers at sogelink.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] ExportToGML with compound CRS
HUOM! Ulkoinen lähettäjä. Älä avaa linkkejä tai liitteitä, ellet tunnista lähettäjää.
OBS! Extern avsändare. Öppna inte länkar eller bilagor om du inte känner igen avsändaren.
NOTE! External sender. Do not open links or attachments unless you recognize the sender.
no other workaround but applying
https://github.com/OSGeo/gdal/pull/14367 (or post patching the output)
Even
Le 15/04/2026 à 16:53, Joep Keijsers via gdal-dev a écrit :
> Greetings,
> I'm trying to export a geometry object to GML using the Python API. The geometry has a compound CRS (EPSG:5973). When exporting to GML, the vertical component of the compound CRS is dropped, although the Z-values are still there. For example:
> from osgeo import ogr, osr
> # Create geometry from WKT string
> srs = osr.SpatialReference()
> srs.ImportFromEPSG(5973)
> wkt = "POINT (30 10 5)"
> geometry = ogr.CreateGeometryFromWkt(wkt, srs)
> # Export to GML
> xml = geometry.ExportToGML(options=['FORMAT=GML32', 'SRSDIMENSION_LOC=GEOMETRY', 'SRSNAME_FORMAT=SHORT', 'GMLID=TestPoint-1'])
> print(xml)
> ... which returns EPSG:11023 instead of EPSG:5973:
> <gml:Point srsName="EPSG:11023" srsDimension="3" gml:id="TestPoint-1"><gml:pos>30 10 5</gml:pos></gml:Point>
> I believe this EPSG code change happens in this line: https://github.com/OSGeo/gdal/blob/30e7918f245022983d84f93f1a53641fd50337ed/ogr/ogr2gmlgeometry.cpp#L562.
> Is there a way to keep the compound CRS in the GML output?
> Version info: gdal 3.12.3
> Thanks!
> Joep
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com/
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
