[gdal-dev] GDAL Debian packaging and Parquet
Even Rouault even.rouault at spatialys.com
Thu Apr 16 08:30:58 PDT 2026
Hi Bas,
I saw from
https://salsa.debian.org/debian-gis-team/gdal/-/commits/experimental
that you've attempted to add Parquet support (I'm thrilled to see that
parquet is now packaged for Debian!), but reverted. I'm curious why
I just tried locally in a debian:unstable Docker image, and it builds
and works fine for me (passes unit tests). In addition to libparquet-dev
you also want to add  libarrow-dataset-dev and libarrow-acero-dev for
full support.
Thanks,
Even
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
