[gdal-dev] GDAL 3.13.0 beta1 available
Roger Bivand Roger.Bivand at nhh.no
Fri Apr 17 11:33:11 PDT 2026
In checking reverse dependencies of > 600 R packages using R packages linking to GDAL with 3.13.0beta1, a change has appeared in at least two cases of reading with the ESRI Shapefile driver, detailed in https://github.com/DOI-USGS/ncdfgeom/issues/107 and https://github.com/eblondel/cleangeo/issues/30. The issues include zip archives of the offending shapefiles. The problem is that geometries read up to and including 3.12.3 as POLYGON are now read as CURVEPOLYGON (one geometry affected in each case). I have not (yet) checked with the latest shapelib - was this change intended?
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
