[gdal-dev] GDAL 3.13.0 beta1 available
Even Rouault
even.rouault at spatialys.com
Fri Apr 17 11:48:15 PDT 2026
Hi Roger,
> In checking reverse dependencies of > 600 R packages using R packages linking to GDAL with 3.13.0beta1, a change has appeared in at least two cases of reading with the ESRI Shapefile driver, detailed in https://github.com/DOI-USGS/ncdfgeom/issues/107 and https://github.com/eblondel/cleangeo/issues/30. The issues include zip archives of the offending shapefiles. The problem is that geometries read up to and including 3.12.3 as POLYGON are now read as CURVEPOLYGON (one geometry affected in each case). I have not (yet) checked with the latest shapelib -
Thanks for the report!
> was this change intended?
Nope, side effect of a recent change in
OGRGeometryFactory::organizePolygons() to better deal with curve
geometries. I'll look at that
Even
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
