[gdal-dev] GDAL 3.13.0 beta1 available
Even Rouault even.rouault at spatialys.com
Mon Apr 20 14:40:28 PDT 2026
Hi Holger,
The intent was to require any grok >= 20.2.8. I suspect the minimum
version check should be expressed differently. Can you come with a patch ?
Even
Le 20/04/2026 à 23:32, Holger Jaekel via gdal-dev a écrit :
> Hi all,
> Am 16.04.26 um 09:39 schrieb Even Rouault via gdal-dev:
>> I've prepared a beta1 of GDAL 3.13.0
> Is there a reason why the Grok version is bound to 20.2.8? I get the
> following message:
> CMake Warning at cmake/helpers/CheckDependentLibrariesCommon.cmake:149
> (find_package):
>   Could not find a configuration file for package "Grok" that is
> compatible
>   with requested version "20.2.8".
>   The following configuration files were considered but not accepted:
>     /usr/lib/cmake/grok-20.3/GrokConfig.cmake, version: 20.3.0
>       The version found is not compatible with the version requested.
> It looks as though it builds fine with version 2.3.0 when I override
> the version number in CheckDependentLibrariesGrok.cmake.
> Best regards,
>   Holger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
