[gdal-dev] /vsicurl, curl and wget
Scott
public at postholer.com
Fri Apr 24 18:52:41 PDT 2026
Greetings!
I'm having issues with a remote file. The following do not work:
gdal vsi copy
https://www.fema.gov/about/reports-and-data/openfema/cl2024_v1.gdb.zip .
gdal vector info
/vsizip/vsicurl/https://www.fema.gov/about/reports-and-data/openfema/cl2024_v1.gdb.zip
curl
-o stf.gdb.zip
All result in a 403, since they're dependent on curl.
However, the following 'wget' works fine:
wget https://www.fema.gov/about/reports-and-data/openfema/cl2024_v1.gdb.zip
Has anyone encountered this before? What am I missing?
Thanks!
Scott
www.postholer.com
