[gdal-dev] /vsicurl, curl and wget
Laurențiu Nicola lnicola at dend.ro
Sat Apr 25 01:27:55 PDT 2026
gdal vector info /vsizip/vsicurl/https://www.fema.gov/about/reports-and-data/openfema/cl2024_v1.gdb.zip works for me (GDAL 3.12.3), but takes a couple of minutes, because ZIP isn't great at random access. I actually cancelled it after it printed the name of the third layer.
HTTP 403 is "Forbidden", which is.. interesting.
Laurentiu
On Sat, Apr 25, 2026, at 04:52, Scott via gdal-dev wrote:
> Greetings!
> I'm having issues with a remote file. The following do not work:
> gdal vsi copy
> https://www.fema.gov/about/reports-and-data/openfema/cl2024_v1.gdb.zip .
> gdal vector info
> curl
> -o stf.gdb.zip
> All result in a 403, since they're dependent on curl.
> However, the following 'wget' works fine:
> wget https://www.fema.gov/about/reports-and-data/openfema/cl2024_v1.gdb.zip
> Has anyone encountered this before? What am I missing?
> Thanks!
> Scott
> www.postholer.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
