[gdal-dev] VRT File Support Within a Zstd-Compressed Zip
Jordan Dauble
Jordan.Dauble at SimBlocks.io
Wed Aug 5 11:17:26 PDT 2026
Greetings, I am new to the GDAL discussion board and am just checking if this is the appropriate method for requesting a feature, such as VRT file support within a Zstd-compressed zip?
Jordan Dauble
SimBlocks LLC, Founder & CEO
407-641-5218
253 Plaza Dr., Ste C
Oviedo, FL 32765
https://www.simblocks.io/
Chair, SISO CIGI PSG<https://www.sisostandards.org/>
From: Jordan Dauble <Jordan.Dauble at SimBlocks.io>
Sent: Sunday, July 19, 2026 5:17 PM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: VRT File Support Within a Zstd-Compressed Zip
Good afternoon, I would like to request that a new feature be added to GDAL. Our team has found that while both libzip and GDAL support Zstd compression, the support does not extend to loading vrt files within a Zstd-compressed zip. We have a use case where the vsizip file handler is used on a Zstd-compressed zip, such as
ogr2ogr outputTest.gpkg /vsizip/{<zip_filename>}/extent.geojson.
We believe the following files would require modification to support this feature:
port/cpl_minizip_unzip.cpp
port/cpl_vsil_gzip.cpp
Jordan Dauble
407-641-5218
Oviedo, FL 32765
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260805/f6afa81e/attachment.htm>
