[gdal-dev] Support for Terrain-RGB
Lars Ahlzen lars at ahlzen.com
Mon Jan 5 13:27:10 PST 2026
Hi Even,
On 05/01/2026 14:50, Even Rouault wrote:
> I would rather see that as a standalone TerrainRGB raster driver,
> leveraging the PNG driver underneath.
That was my original thought as well. Then, after thinking about
different use cases I thought adding a gdaldem mode would allow for a
wider range of workflows.
That said, you probably have a better idea of what would work best for
GDAL as a whole, so I can look in that direction.
> For the read side, if one is desired (write-only drivers are
> possible), is there a way in metadata or file naming of distinguishing
> a regular RGB PNG file from a Terrain-RGB one? If not, the Identify()
> function should rely on users providing a "TerrainRGB:" prefix or
> specifying explicitly the driver in the
> GDALOpenInfo::papszAllowedDrivers member (testable with
>  poOpenInfo->IsSingleAllowedDriver("TerrainRGB") )
I don't think there's any sort of indication of the encoding in the
files themselves (please correct me if I'm wrong). I imagine the need to
decode Terrain-RGB back into a single-band DEM would be rare anyway, so
a write-only driver might be sufficient.
- Lars
