[gdal-dev] Support for Terrain-RGB
Even Rouault
even.rouault at spatialys.com
Mon Jan 5 13:42:35 PST 2026
Le 05/01/2026 à 22:27, Lars Ahlzen a écrit :
> Hi Even,
> On 05/01/2026 14:50, Even Rouault wrote:
>> I would rather see that as a standalone TerrainRGB raster driver,
>> leveraging the PNG driver underneath.
> That was my original thought as well. Then, after thinking about
> different use cases I thought adding a gdaldem mode would allow for a
> wider range of workflows.
> That said, you probably have a better idea of what would work best for
> GDAL as a whole, so I can look in that direction.
The rationale behind suggesting a driver rather than a new mode to
gdaldem is that gdaldem modes are agnostic of the output format. Here it
is really a file format issue.
http://www.spatialys.com
