[gdal-dev] ogr2ogr explanations for error XML parsing of GML file failed?
Even Rouault even.rouault at spatialys.com
Mon Jan 12 08:34:18 PST 2026
Hi Jeroen,
can you type "set" to list environment variables that are defined, both
in a terminal from QGIS or the Windows prompt, (possibly redirecting to
file, like "set > env_vars.txt"), and compare the differences
Even
Le 12/01/2026 à 17:06, Jeroen Hovens via gdal-dev a écrit :
> Hi,
> I use QGIS on Windows10 which comes with GDAL. The latest QGIS LTR
> (3.40.14) uses GDAL 3.12.1
> In QGIS I can open a terminal (browser panel, rightclick a folder and
> select Open in Terminal) and immediately use ogr2ogr to convert a WFS
> to a geopackage, because QGIS has altered the path to include the GDAL
> directory
> However, with some WFS services ogr2ogr throws an error. I have no
> trouble using those WFS services in QGIS.
> For instance, this one I can’t convert:
> ogr2ogr -f gpkg test.gpkg
> WFS:"https://service.pdok.nl/kadaster/bestuurlijkegebieden/wfs/v1_0?"
> Provinciegebied -overwrite -nln provincie_kadaster
> But this one I can:
> ogr2ogr -f gpkg test2.gpkg
> WFS:"https://map.data.amsterdam.nl/maps/gebieden" wijk -overwrite -nln
> amsterdam_wijk
> The first WFS is part of a large Dutch open data organization and
> depending on which WFS  I choose from them I see two different errors:
> ERROR 1: XML parsing of GML file failed : no element found at line 27,
> column 31065   (or different numbers)
> Or
> ERROR 1: XML parsing of GML file failed : unclosed token at line 555,
> column 9
> I was able to compare a debug on with someone who was able to convert
> the WFS to a gpkg and this part was surely different
> VSICURL: Read attempt beyond end of file
> After this, the error appeared.
> To make things more complicated:
> When I open a Windows Prompt (terminal) and set a path to the GDAL
> directory in QGIS using set PATH=%PATH%;C:\Program Files\QGIS 3.40.14\bin
> I can also use ogr2ogr.
> Interestingly, now I can convert both WFS datasets to gpkg.
> What could be different with the QGIS Terminal setting from a Windows
> Prompt setting with the path set that would explain the errors?
> What might be different in both WFS services that triggers these errors?
> Kind regards,
> Jeroen Hovens
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260112/d5510ae7/attachment.htm>
