[gdal-dev] ogr2ogr explanations for error XML parsing of GML file failed?
Even Rouault
even.rouault at spatialys.com
Mon Jan 12 10:07:18 PST 2026
ok,
so the issue was related to QGIS setting VSI_CACHE=YES, which triggered
a bug in /vsicurl_streaming/
So the workaround is that you type "set VSI_CACHE=" in the QGIS console
Proper fix queued in https://github.com/OSGeo/gdal/pull/13690
Even
Le 12/01/2026 à 17:59, Jeroen Hovens a écrit :
> Hi Even,
> Find attached two txt files.
> env_var_winprompt is the normal windows prompt terminal after adding
> the QGIS bin folder to path
> env_var_qgisterminal is the QGIS terminal as is, no changes made
> Jeroen
> *Van:*Even Rouault <even.rouault at spatialys.com>
> *Verzonden:* maandag 12 januari 2026 17:34
> *Aan:* Jeroen Hovens <jeroen at groenebij.nl>; gdal-dev at lists.osgeo.org
> *Onderwerp:* Re: [gdal-dev] ogr2ogr explanations for error XML parsing
> of GML file failed?
> Hi Jeroen,
> can you type "set" to list environment variables that are defined,
> both in a terminal from QGIS or the Windows prompt, (possibly
> redirecting to file, like "set > env_vars.txt"), and compare the
> differences
> Even
> Le 12/01/2026 à 17:06, Jeroen Hovens via gdal-dev a écrit :
> Hi,
> I use QGIS on Windows10 which comes with GDAL. The latest QGIS LTR
> (3.40.14) uses GDAL 3.12.1
> In QGIS I can open a terminal (browser panel, rightclick a folder
> and select Open in Terminal) and immediately use ogr2ogr to
> convert a WFS to a geopackage, because QGIS has altered the path
> to include the GDAL directory
> However, with some WFS services ogr2ogr throws an error. I have no
> trouble using those WFS services in QGIS.
> For instance, this one I can’t convert:
> ogr2ogr -f gpkg test.gpkg
> WFS:"https://service.pdok.nl/kadaster/bestuurlijkegebieden/wfs/v1_0?"
> <https://service.pdok.nl/kadaster/bestuurlijkegebieden/wfs/v1_0?>
> Provinciegebied -overwrite -nln provincie_kadaster
> But this one I can:
> ogr2ogr -f gpkg test2.gpkg
> WFS:"https://map.data.amsterdam.nl/maps/gebieden"
> <https://map.data.amsterdam.nl/maps/gebieden> wijk -overwrite -nln
> amsterdam_wijk
> The first WFS is part of a large Dutch open data organization and
> depending on which WFS I choose from them I see two different errors:
> ERROR 1: XML parsing of GML file failed : no element found at line
> 27, column 31065 (or different numbers)
> Or
> ERROR 1: XML parsing of GML file failed : unclosed token at line
> 555, column 9
> I was able to compare a debug on with someone who was able to
> convert the WFS to a gpkg and this part was surely different
> VSICURL: Read attempt beyond end of file
> After this, the error appeared.
> To make things more complicated:
> When I open a Windows Prompt (terminal) and set a path to the GDAL
> directory in QGIS using set PATH=%PATH%;C:\Program Files\QGIS
> 3.40.14\bin
> I can also use ogr2ogr.
> Interestingly, now I can convert both WFS datasets to gpkg.
> What could be different with the QGIS Terminal setting from a
> Windows Prompt setting with the path set that would explain the
> errors?
> What might be different in both WFS services that triggers these
> errors?
> Kind regards,
> Jeroen Hovens
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260112/56d96c0f/attachment.htm>
