[gdal-dev] Adding resource files to GDAL artifacts
Howard Butler
howard at hobu.co
Tue Jan 27 06:55:33 PST 2026
The GDAL emailing list is not your AI prompt. Please stop repeatedly posting questions you will be banned from posting again.
Howard
> On Jan 27, 2026, at 8:34 AM, John Smith via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> Hello
> Is there any easy way to add "ProductName", "Company Name" etc to all the DLLs and EXEs produced by building GDAL source? I usually build GDAL using CMake."
> I want checking if its possible/allowed to add this information to the DLLs and EXEs being built.
> BR
> John
> From: John Smith <johnsmith7862025 at outlook.com>
> Sent: Friday, January 23, 2026 8:27 AM
> To: Even Rouault <even.rouault at spatialys.com>; David Klaus via gdal-dev <gdal-dev at lists.osgeo.org>
> Subject: Adding resource files to GDAL artifacts
> Hello
> BR
> John
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260127/945a9eff/attachment-0001.htm>
