[gdal-dev] Adding resource files to GDAL artifacts
John Smith johnsmith7862025 at outlook.com
Tue Jan 27 07:26:36 PST 2026
Howard,
Noted your point.
Please note that I just replied to the question asked by Andrew Bell. It wasn't a new question but an answer to the previous question posed to me.
Sent: Tuesday, January 27, 2026 2:55 PM
To: John Smith <johnsmith7862025 at outlook.com>
Cc: gdal dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Adding resource files to GDAL artifacts
The GDAL emailing list is not your AI prompt. Please stop repeatedly posting questions you will be banned from posting again.
Howard
On Jan 27, 2026, at 8:34 AM, John Smith via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
Hello
Is there any easy way to add "ProductName", "Company Name" etc to all the DLLs and EXEs produced by building GDAL source? I usually build GDAL using CMake."
I want checking if its possible/allowed to add this information to the DLLs and EXEs being built.
BR
John
Sent: Friday, January 23, 2026 8:27 AM
To: Even Rouault <even.rouault at spatialys.com>; David Klaus via gdal-dev <gdal-dev at lists.osgeo.org>
Subject: Adding resource files to GDAL artifacts
Hello
BR
John
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260127/49014b39/attachment.htm>
