[gdal-dev] OGRCoordinateTransformation::Transform() memory usage clarification
Even Rouault even.rouault at spatialys.com
Fri Mar 6 10:00:38 PST 2026
It would be interesting if you could bench using proj_trans() or
proj_trans_array() vs OGRCoordinateTransformation::Transform(). My gut
feeling would be that the CPU cost of most coordinate transformations
would be the dominant part, but I might be wrong.
Even
Le 06/03/2026 à 18:40, David Klaus via gdal-dev a écrit :
> Hello GDAL Community,
> I am currently optimizing a routine that transforms a large number of
> points using OGRCoordinateTransformation::Transform().
> As it stands, this function requires separate arrays for the x, y, z
> (optional), and t (optional) data. From a memory perspective, it seems
> that this approach requires the CPU to fetch cache lines from multiple
> different memory pools to process a single coordinate tuple. I am
> concerned this might lead to cache thrashing and degraded performance
> for massive arrays.
> Is there an existing method or best practice to provide point data to
> GDAL in an interleaved, cache-friendly manner? I believe that this can
> be done using proj directly, but I don't see a solution with GDAL.
> Alternatively is this separation intentional, making my cache concerns
> less of an issue in practice?
> Thank you for your time and any insights you can provide,
> David Klaus
> Carlson Software
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and
> others authorized to receive it. If you are not the recipient, you are
> hereby notified that any disclosure, copying, distribution or taking
> action in relation of the contents of this information is strictly
> prohibited and may be unlawful.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260306/6d9ce6f1/attachment.htm>
