[gdal-dev] OGRCoordinateTransformation::Transform() memory usage clarification
David Klaus dklaus at carlsonsw.com
Fri Mar 6 09:40:48 PST 2026
Hello GDAL Community,
I am currently optimizing a routine that transforms a large number of
points using OGRCoordinateTransformation::Transform().
As it stands, this function requires separate arrays for the x, y, z
(optional), and t (optional) data. From a memory perspective, it seems that
this approach requires the CPU to fetch cache lines from multiple different
memory pools to process a single coordinate tuple. I am concerned this
might lead to cache thrashing and degraded performance for massive arrays.
Is there an existing method or best practice to provide point data to GDAL
in an interleaved, cache-friendly manner? I believe that this can be done
using proj directly, but I don't see a solution with GDAL.
Alternatively is this separation intentional, making my cache concerns less
of an issue in practice?
Thank you for your time and any insights you can provide,
David Klaus
Carlson Software
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260306/c4198954/attachment-0001.htm>
