[gdal-dev] GSoC Proposal Idea: Strengthening GDAL Python Stub Generation via Runtime Consistency Validation
Even Rouault
even.rouault at spatialys.com
Tue Mar 10 01:59:34 PDT 2026
Sionigdha,
Thanks for your proposal. We've discussed among several maintainers, but
no one appears to be available to mentor a GSoC project.
Even
Le 09/03/2026 à 16:21, Sionigdha Sadhukhan via gdal-dev a écrit :
> I also wanted to ask is GDAL planning to participate under the OSGeo
> GSoC 2026 umbrella this year? I noticed there isn't a GDAL-specific
> ideas page yet and wanted to check before finalizing my proposal. I
> have also shared my introduction and proposal direction on the OSGeo
> Discourse here:
> https://discourse.osgeo.org/t/introduction-sionigdha-sadhukhan-gsoc-2026-proposal-gdal-python-stub-hardening-runtime-validation-type-coverage/152757
> <https://discourse.osgeo.org/t/introduction-sionigdha-sadhukhan-gsoc-2026-proposal-gdal-python-stub-hardening-runtime-validation-type-coverage/152757>
> If any maintainer would be open to mentoring or giving feedback on the
> proposal draft, I would be very grateful.
> On Tue, 3 Mar 2026 at 18:46, Sionigdha Sadhukhan
> <snigdha.lee75 at gmail.com> wrote:
> Hello GDAL developers,
> Over the past weeks, while contributing to GDAL and working on
> Python binding-related issues and PRs, I have been studying the
> current Python stub generation pipeline in detail. In particular,
> I explored the |docstub| integration and the implementation in
> |_analysis.py|, |_docstrings.py|, and |_stubs.py|, along with
> recent PRs related to docstring cleanup and stub generation.
> From examining the code, I understand that:
> |.pyi| files are generated entirely from docstrings using a
> custom Lark grammar.
> Type resolution is handled through |TypeMatcher| and import
> reconstruction.
> Unresolved types fall back to |_typeshed.Incomplete|.
> There is currently no mechanical validation step ensuring that
> generated stubs remain consistent with the actual runtime
> callable signatures produced by SWIG.
> This means the stub layer is structurally decoupled from the
> runtime bindings, and drift between:
> C++ → SWIG → Python runtime → docstrings → generated stubs
> is theoretically possible without automated detection.
> For GSoC, I would like to explore a project focused on hardening
> and modernizing this pipeline through runtime–stub consistency
> validation and stricter enforcement mechanisms.
> A possible scope could include:
> *Runtime–Stub Signature Validator*
> Import |osgeo| modules and inspect public callables using
> |inspect.signature()|.
> Parse generated |.pyi| files.
> Detect mismatches in parameter names, counts, defaults, and
> return presence.
> Produce structured reports of inconsistencies.
> *Stricter Stub Generation Mode*
> Optionally fail (or emit stronger diagnostics) on unresolved
> types instead of silently aliasing to |_typeshed.Incomplete|.
> Provide measurable metrics on annotation coverage and
> unresolved types.
> *CI Integration*
> Integrate validation checks into CI to prevent silent drift
> over time.
> Keep the approach incremental and compatible with the existing
> docstring-driven workflow.
> The goal would not be to redesign SWIG bindings or replace the
> current system, but to introduce a validation and enforcement
> layer that increases confidence in typing correctness, IDE
> support, and long-term maintainability of the Python bindings.
> Before developing this into a formal proposal, I would really
> appreciate feedback on:
> Whether runtime–stub consistency validation aligns with
> current Python binding priorities.
> Whether there are known constraints or prior efforts in this
> direction.
> Whether this scope would be appropriate and realistic for a
> GSoC project.
> Thank you very much for your time. I would be happy to refine or
> narrow this idea based on feedback.
> Best regards,
> Sionigdha
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260310/4a95f27e/attachment.htm>
