[gdal-dev] CPL_LSBSINT64PTR and CPL_LSBUINT64PTR ?
Andrew C Aitchison
gdal at aitchison.me.uk
Tue Mar 10 07:17:47 PDT 2026
port/cpl_port.h says
/** Return a Int16 from the 2 bytes ordered in LSB order at address x.
* @deprecated Use rather CPL_LSBSINT16PTR or CPL_LSBUINT16PTR for
explicit
* signedness. */
#define CPL_LSBINT16PTR(x)
and
/** Return a Int32 from the 4 bytes ordered in LSB order at address x.
* @deprecated Use rather CPL_LSBSINT32PTR or CPL_LSBUINT32PTR for
explicit
* signedness. */
#define CPL_LSBINT32PTR(x)
... but I cannot find any of
CPL_LSBINT64PTR
CPL_LSBSINT64PTR
or
CPL_LSBUINT64PTR.
I have the address of a 64bit unsigned integer in little endian order.
Which macro should I use to put it into a uint64_t variable ?
Thanks,
Andrew C. Aitchison Kendal, UK
andrew at aitchison.me.uk
