[gdal-dev] CPL_LSBSINT64PTR and CPL_LSBUINT64PTR ?
Even Rouault even.rouault at spatialys.com
Tue Mar 10 07:22:09 PDT 2026
Andrew,
> I have the address of a 64bit unsigned integer in little endian order.
> Which macro should I use to put it into a uint64_t variable ?
Something like:
uint64_t x;
memcpy(&x, ptr, sizeof(x));
CPL_LSBPTR64(&x);
Even
http://www.spatialys.com
