[gdal-dev] CPL_LSBSINT64PTR and CPL_LSBUINT64PTR ?
Andrew C Aitchison
gdal at aitchison.me.uk
Tue Mar 10 12:58:44 PDT 2026
On Tue, 10 Mar 2026, Even Rouault wrote:
> Andrew,
>> I have the address of a 64bit unsigned integer in little endian order.
>> Which macro should I use to put it into a uint64_t variable ?
> Something like:
> uint64_t x;
> memcpy(&x, ptr, sizeof(x));
> CPL_LSBPTR64(&x);
Thanks.
Andrew C. Aitchison Kendal, UK
andrew at aitchison.me.uk
