[gdal-dev] GDAL Process Exit Codes and stderr
Peter Townsend
peter.townsend at maplarge.com
Tue Mar 10 11:17:13 PDT 2026
I thought it'd be easiest to just ask.
When you run any of the GDAL executables, is it a safe assumption to say
that if the process exit code is 0 that it really did succeed at whatever
you told it to do? Despite whether it wrote anything out to stderr?
To word it a bit differently, if the process code is not zero, can I assume
that it didn't work out and I should stop whatever I was doing with GDAL?
I'm using v3.9.3 if that helps narrow down the behavior.
Thanks!
Peter Townsend
Senior Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260310/bbc26e91/attachment.htm>
