[gdal-dev] Anyone has already forgotten the /vsicurl/ prefix?
Scott
public at postholer.com
Fri Mar 27 12:44:37 PDT 2026
Embarrassingly, I've caught myself looking into the documentation for
/vsihttp/ on more than one occasion. It might be cool to have it,
possibly with its own set of --co options.
But, yeah, the new default action you outlined sounds good!
Scott
On 3/27/26 10:08, Even Rouault via gdal-dev wrote:
> Hi,
> I suspect that almost every GDAL user, even the most experienced, has
> made the mistake of typing "gdalinfo https://example.com/my.tif" instead
> of "gdalinfo /vsicurl/https://example.com/my.tif". Both commands work,
> but the first one triggers the HTTP pseudo-driver which downloads the
> entire file into memory before passing it to the GeoTIFF driver, while
> the second reads it in chunks.
> I would be inclined to modify the GDALOpen() logic with the following
> tweak: if the passed filename starts with "http://" or "https://",
> automatically prepend "/vsicurl/", unless the string has query
> parameters. That restriction about not having query parameters is
> because in most of the cases this is for dynamically generated resources
> that don't support range requests.
> For users really wanting to go through the HTTP pseudo-driver, we'd
> modify it to accept a "HTTP:" prefix before the URL or it would trigger
> if using the "-if HTTP" argument of command line utilities (or
> allowed_drivers = ["HTTP"] in the API)
> So this change wouldn't be fully backwards compatible, but I feel it
> would still make more people happy than unhappy.
> Thoughts?
> Even
