[gdal-dev] Motion : Accept RFC 112 - Remove Mono MCS support from the CMAKE scripts.
Even Rouault even.rouault at spatialys.com
Sat May 2 14:18:55 PDT 2026
+1 Even (I had a successful try of the implementation PR with ubuntu 24.04)
Le 27/04/2026 à 17:06, Paul Harwood via gdal-dev a écrit :
> I created and published RFC 112
> <https://github.com/OSGeo/gdal/pull/14368/changes> to propose that we
> remove support for Mono mcs from the CMAKE scripts.
> The implementation PR is now available
> <https://github.com/OSGeo/gdal/pull/14397>
> I would like to propose that this RFC is accepted.
> Thanks
> Paul
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260502/36f7aba8/attachment-0001.htm>
