[gdal-dev] GDAL 3.13.0 release candidate available
Greg Troxel
gdt at lexort.com
Mon May 4 08:15:33 PDT 2026
Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org> writes:
> I have prepared a GDAL/OGR 3.13.0 "Iowa City" release candidate.
Built fine on NetBSD 10 amd64.
NEWS has a pointer to MIGRATION_GUIDE.TXT, and that file contains a link
to online docs (which feels like a minor bug; the migration guide should
be IMHO be in the sources). But, on following the link, there is no
3.12 to 3.13 content.
In NEWS,
a missed newly-installed file: include/gdal_mem.h
there are a lot of new gdal subcommand man pages, not mentioned in
NEWS. It's not clear to me how users would find these.
there are a lot of new bash completion functions, not mentoined in
NEWS
Not a big deal for users, but I try to line up changes in the set of
installed files with NEWS to make sure I'm not making a packaging error.
Removing the shlib change, the packing list changes by adding the
following:
+include/gdal_mem.h
+include/gdal_thread_pool.h
+include/ogr_refcountedptr.h
+man/man1/gdal-dataset-check.1
+man/man1/gdal-raster-read.1
+man/man1/gdal-raster-write.1
+man/man1/gdal-vector-combine.1
+man/man1/gdal-vector-create.1
+man/man1/gdal-vector-dissolve.1
+man/man1/gdal-vector-export-schema.1
+man/man1/gdal-vector-read.1
+man/man1/gdal-vector-rename-layer.1
+man/man1/gdal-vector-sort.1
+man/man1/gdal-vector-update.1
+man/man1/gdal-vector-write.1
+share/bash-completion/completions/gdal2tiles
+share/bash-completion/completions/gdal2xyz
+share/bash-completion/completions/gdal_calc
+share/bash-completion/completions/gdal_edit
+share/bash-completion/completions/gdal_fillnodata
+share/bash-completion/completions/gdal_merge
+share/bash-completion/completions/gdal_polygonize
+share/bash-completion/completions/gdal_proximity
+share/bash-completion/completions/gdal_retile
+share/bash-completion/completions/gdal_sieve
+share/bash-completion/completions/gdalcompare
+share/bash-completion/completions/gdalmove
+share/bash-completion/completions/ogr_layer_algebra
+share/bash-completion/completions/ogrmerge
And, with packager hat off and user hat on:
GeoJSON driver:
* minify output (no whitespace) for Feature objects
To me, this is a regression rather than a feature. A key point for
geojson to me is that it's nerd readable, and it makes it harder for
what I see as a minor change in file size. I can see a switch to ask
for minified output, but I really wonder who sues geojson and what they
on balance care about. I can't really say that I read these files a
lot, so the byte savings might well be on better across all users.
On a real dataset I happen to be working on, with 234 point features:
41231 bytes 3.12.2
36338 bytes 3.13.0
126976 bytes in the geopackage storing the features
I do very much appreciate that geojson as written has one feature per
line. That is perhaps a compromise between full-on remove all whitspace
and nerd-reading comfort.
