[gdal-dev] GDAL 3.13.0 release candidate available
Even Rouault
even.rouault at spatialys.com
Mon May 4 03:46:42 PDT 2026
I have prepared a GDAL/OGR 3.13.0 "Iowa City" release candidate.
I'll call for a vote promoting it later this week if no serious problems are
reported before.
NEWS at:
https://github.com/OSGeo/gdal/blob/v3.13.0RC1/NEWS.md
Pick up an archive among the following ones (by ascending size):
https://download.osgeo.org/gdal/3.13.0/gdal-3.13.0rc1.tar.xz
https://download.osgeo.org/gdal/3.13.0/gdal-3.13.0rc1.tar.gz
https://download.osgeo.org/gdal/3.13.0/gdal3130rc1.zip
A snapshot of the gdalautotest suite is also available :
https://download.osgeo.org/gdal/3.13.0/gdalautotest-3.13.0rc1.zip
A snapshot of the documentation is at:
https://download.osgeo.org/gdal/3.13.0/gdal3130doc.zip
The release/3.13 branch has now been created, and master is now open for
3.14.0dev.
The following changes have been done since beta2:
- GDALRasterBand::IRasterIO(): avoid potential int overflow
(ossfuzz#506741816)
- GDALAlgorithm: check Run() is called at most once per instance
- gdal: make sure stdout is properly flushed (#14477)
- gdal raster contour: rename --src-nodata to --input-nodata
- gdal raster edit: add --color-map to set a color table on a band, and
--unset-color-table to remove it
- gdal raster footprint: rename --dst-crs to --output-crs
- gdal raster footprint: rename --src-nodata to --input-nodata
- gdal raster index: rename --dst-crs to --output-crs
- gdal raster reproject: rename --src-crs and --dst-crs to --input-crs and
--output-crs
- gdal raster reproject: rename --src-nodata,--dst-nodata to --input-nodata,
--output-nodata
- gdal raster rgb-to-palette: rename --dst-nodata to --output-nodata
- gdal raster scale: rename --[src/dst][min/max] to
--[input/output][min/max]
- gdal raster stack/mosaic: rename --src-nodata,--dst-nodata to
--input-nodata,
--output-nodata
- gdal raster tile: rename --dst-nodata to --output-nodata
- gdal raster viewshed: rename --dst-nodata to --output-nodata
- gdal-bash-completion: make it msys2 compatible
- AIG driver: avoid potential stack buffer overflow in CCITTRLE code,
and a read heap buffer overflow when opening 'hdr.adf' (#14469)
- GRIB driver: fix heap-Buffer-Overflow WRITE on corrupted/hostile data
(#14455)
- GRIB driver: avoid heap-buffer-overflow in specunpack() (#14470)
- HDF4-EOS: fix various vulnerabilities (#14428, #14430, #14431, #14440)
- ISIS3 driver: correctly deal with PVL keys with '/' character in JSON
representation (#14443)
- MRF driver: Fix against corrupted/hostile data (#14472)
- NITF driver: fix potential stack buffer overflow in
NITFLoadAttributeSection() (#14449)
- PCIDSK driver: avoid integer overflow (ossfuzz#500171204)
- TileDB driver: do not try to identify /vsis3/.../file.tif files
- VRT driver: fix heap-buffer-overflow on misconfigured
VRTProcessedDataset (#14462)
- WMSDriverSubdatasetInfo::parseFileName(): fix crash if LAYERS= is not
fully capitalized (ossfuzz#505232394)
- gdal vector concat: rename --src-crs and --dst-crs to --input-crs and
--output-crs
- gdal vector clip: make it preserve aspatial layers in passthroug mode,
rather
than wiping out their features (#14438)
- gdal vector index: rename --dst-crs to --output-crs
- gdal vector make-point: rename --dst-crs to --output-crs
- gdal vector materialize: fix issues with SQLite format (#14444)
- gdal vector rasterize: make --tap depends on --resolution (#14458)
- gdal vector reproject: rename --src-crs and --dst-crs to --input-crs and
--output-crs
- gdal vector reproject/clean-coverage/simplify-coverage: make it
passthrough
for non-spatial layers (#14446)
- gdal vector set-field-type: rename --src-field-type to --input-field-type
- OpenFileGDB driver: when exploring layers in GDB_Items, report deleted
rows with a warning instead of a failure (#14424)
- PG driver: avoid error when setting a NULL geometry field on a result
layer without geometry field
- Python bindings: Make gdal.alg.xxxx(...) accept aliases and hidden
aliases of argument names
- Python bindings: Handle numpy types in Feature.SetField
Best regards,
Even
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
