[gdal-dev] Motion : Accept RFC 112 - Remove Mono MCS support from the CMAKE scripts.
Michael Smith
michael.smith.erdc at gmail.com
Sun May 3 13:48:13 PDT 2026
+1
Mike
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
On 5/3/26, 4:17 PM, "gdal-dev on behalf of Rahkonen Jukka via gdal-dev" <gdal-dev-bounces at lists.osgeo.org <mailto:gdal-dev-bounces at lists.osgeo.org> on behalf of gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>> wrote:
+1
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org <mailto:gdal-dev-bounces at lists.osgeo.org>> käyttäjän Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>> puolesta
Lähetetty: Sunnuntai 3. toukokuuta 2026 0.18
Vastaanottaja: Paul Harwood <runette at gmail.com <mailto:runette at gmail.com>>; gdal-dev <gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>>
Aihe: Re: [gdal-dev] Motion : Accept RFC 112 - Remove Mono MCS support from the CMAKE scripts.
HUOM! Ulkoinen lähettäjä. Älä avaa linkkejä tai liitteitä, ellet tunnista lähettäjää.
OBS! Extern avsändare. Öppna inte länkar eller bilagor om du inte känner igen avsändaren.
NOTE! External sender. Do not open links or attachments unless you recognize the sender.
+1 Even (I had a successful try of the implementation PR with ubuntu 24.04)
Le 27/04/2026 à 17:06, Paul Harwood via gdal-dev a écrit :
I created and published RFC 112 to propose that we remove support for Mono mcs from the CMAKE scripts.
The implementation PR is now available
I would like to propose that this RFC is accepted.
Thanks
Paul
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
http://www.spatialys.com <http://www.spatialys.com>
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
