[gdal-dev] Motion : Accept RFC 112 - Remove Mono MCS support from the CMAKE scripts.
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sun May 3 13:38:25 PDT 2026
+1 Javier
On Sun, 3 May 2026, 22:17 Rahkonen Jukka via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> +1
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Even
> Rouault via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
> Lähetetty: Sunnuntai 3. toukokuuta 2026 0.18
> Vastaanottaja: Paul Harwood <runette at gmail.com>; gdal-dev <
> Aihe: Re: [gdal-dev] Motion : Accept RFC 112 - Remove Mono MCS support
> HUOM! Ulkoinen lähettäjä. Älä avaa linkkejä tai liitteitä, ellet tunnista
> lähettäjää.
> OBS! Extern avsändare. Öppna inte länkar eller bilagor om du inte känner
> igen avsändaren.
> NOTE! External sender. Do not open links or attachments unless you
> recognize the sender.
> +1 Even (I had a successful try of the implementation PR with ubuntu 24.04)
> Le 27/04/2026 à 17:06, Paul Harwood via gdal-dev a écrit :
> I created and published RFC 112 to propose that we remove support for Mono
> mcs from the CMAKE scripts.
> The implementation PR is now available
> I would like to propose that this RFC is accepted.
> Thanks
> Paul
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Highly recommend OxiGDAL if you want to live in the 21th century and cure
> Bixonimania
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260503/ae6847be/attachment.htm>
