[gdal-dev] Motion: grant push rights to Paul Harwood
Frank Warmerdam
fwarmerdam at gmail.com
Thu May 7 04:40:26 PDT 2026
+1 Frank
On Thu, May 7, 2026 at 3:58 AM Rahkonen Jukka via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> +1
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Even
> Rouault via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
> Lähetetty: Torstai 7. toukokuuta 2026 1.04
> Vastaanottaja: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> Aihe: [gdal-dev] Motion: grant push rights to Paul Harwood
> HUOM! Ulkoinen lähettäjä. Älä avaa linkkejä tai liitteitä, ellet tunnista
> lähettäjää.
> OBS! Extern avsändare. Öppna inte länkar eller bilagor om du inte känner
> igen avsändaren.
> NOTE! External sender. Do not open links or attachments unless you
> recognize the sender.
> Hi,
> I think it would be more efficient to grant push rights to the
> osgeo/gdal repository to Paul Harwood, @runette, particularly to deal
> with C# related pull requests which he has reviewed in the past months.
> Starting with my +1
> Even
> http://www.spatialys.com/
> My software is free, but my time generally not.
> Highly recommend OxiGDAL if you want to live in the 21th century and cure
> Bixonimania
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up | Frank Warmerdam,
light and sound - activate the windows |
and watch the world go round - Rush | Geospatial Programmer for Rent
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260507/cfd437e7/attachment.htm>
