[gdal-dev] clang-tidy 23 bugprone-signed-bitwise and CPL_LSBINT32PTR macros
Even Rouault
even.rouault at spatialys.com
Sun May 10 07:14:36 PDT 2026
Andrew,
does https://github.com/OSGeo/gdal/pull/14524 fix the warning?
Even
Le 10/05/2026 à 16:02, Andrew C Aitchison via gdal-dev a écrit :
> clang-tidy 23 (I'm using Ubuntu 26.04 with build
> ++20260508083129+d791e3a6f4c8-1~exp1~20260508083148.481
> from llvm-toolchain-snapshot at https://www.llvm.org/)
> has a new? check bugprone-signed-bitwise.
> This check objects to macros like CPL_LSBINT32PTR:
> clang-tidy --config="{Checks: 'bugprone-signed-bitwise', CheckOptions:
> {bugprone-signed-bitwise.IgnorePositiveIntegerLiterals: true}}"
> frmts/raw/lcpdataset.cpp
> reports 63 warnings of [bugprone-signed-bitwise], starting with:
> /home/werdna/gdal/git/frmts/raw/lcpdataset.cpp:171:10: warning: use of
> a signed integer operand with a binary bitwise operator
> 171 | if ((CPL_LSBSINT32PTR(poOpenInfo->pabyHeader) != 20 &&
> /usr/local/gdal/git.llvm/include/cpl_port.h:799:53: note: expanded
> from macro 'CPL_LSBSINT32PTR'
> 799 | #define CPL_LSBSINT32PTR(x) CPL_STATIC_CAST(GInt32,
> CPL_LSBINT32PTR(x))
> /usr/local/gdal/git.llvm/include/cpl_port.h:786:6: note: expanded from
> macro 'CPL_LSBINT32PTR'
> 786 | ((*CPL_REINTERPRET_CAST(const GByte *, x))
> 787 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 1) << 8U)
> 788 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 2) << 16U)
> /usr/local/gdal/git.llvm/include/cpl_port.h:181:55: note: expanded
> from macro 'CPL_STATIC_CAST'
> 181 | #define CPL_STATIC_CAST(type, expr) static_cast<type>(expr)
> I suspect that default type-promotion from an unsigned GByte
> to a *signed* int does not help here.
> Not exactly a bug, but annoying.
http://www.spatialys.com
