[gdal-dev] clang-tidy 23 bugprone-signed-bitwise and CPL_LSBINT32PTR macros
Andrew C Aitchison
gdal at aitchison.me.uk
Mon May 11 05:11:59 PDT 2026
On Sun, 10 May 2026, Even Rouault wrote:
> Andrew,
> does https://github.com/OSGeo/gdal/pull/14524 fix the warning?
With that change, clang-tidy is happy, but now the compile breaks if I use
`clang++ -Wsign-conversion`:
In file included from /usr/local/gdal/git.llvm/include/gdal_dataset.h:18:
/usr/local/gdal/git.llvm/include/cpl_port.h:808:33: error: implicit
conversion changes signedness: 'int' to 'uint32_t' (aka 'unsigned int')
[-Werror,-Wsign-conversion]
808 | uint32_t unsigned_val = CPL_LSBINT32PTR(x);
/usr/local/gdal/git.llvm/include/cpl_port.h:788:62: note: expanded from
macro
'CPL_LSBINT32PTR'
786 | ((*CPL_REINTERPRET_CAST(const GByte *, x)) | \
787 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 1) << 8) | \
788 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 2) << 16) | \
789 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 3) << 24))
qed.cpp:122:30: note: in instantiation of function template specialization
'CPL_LSBSINT32PTR<unsigned char>' requested here
122 | return (static_cast<int>(CPL_LSBSINT32PTR(buf)));
> Even
> Le 10/05/2026 à 16:02, Andrew C Aitchison via gdal-dev a écrit :
>> clang-tidy 23 (I'm using Ubuntu 26.04 with build
>> ++20260508083129+d791e3a6f4c8-1~exp1~20260508083148.481
>> from llvm-toolchain-snapshot at https://www.llvm.org/)
>> has a new? check bugprone-signed-bitwise.
>> This check objects to macros like CPL_LSBINT32PTR:
>> clang-tidy --config="{Checks: 'bugprone-signed-bitwise', CheckOptions:
>> {bugprone-signed-bitwise.IgnorePositiveIntegerLiterals: true}}"
>> frmts/raw/lcpdataset.cpp
>> reports 63 warnings of [bugprone-signed-bitwise], starting with:
>> /home/werdna/gdal/git/frmts/raw/lcpdataset.cpp:171:10: warning: use of a
>> signed integer operand with a binary bitwise operator
>> 171 | if ((CPL_LSBSINT32PTR(poOpenInfo->pabyHeader) != 20 &&
>> /usr/local/gdal/git.llvm/include/cpl_port.h:799:53: note: expanded from
>> macro 'CPL_LSBSINT32PTR'
>> 799 | #define CPL_LSBSINT32PTR(x) CPL_STATIC_CAST(GInt32,
>> CPL_LSBINT32PTR(x))
>> /usr/local/gdal/git.llvm/include/cpl_port.h:786:6: note: expanded from
>> macro 'CPL_LSBINT32PTR'
>> 787 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 1) << 8U) | \
>> 788 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 2) << 16U) | \
>> /usr/local/gdal/git.llvm/include/cpl_port.h:181:55: note: expanded from
>> macro 'CPL_STATIC_CAST'
>> 181 | #define CPL_STATIC_CAST(type, expr) static_cast<type>(expr)
>> I suspect that default type-promotion from an unsigned GByte
>> to a *signed* int does not help here.
>> Not exactly a bug, but annoying.
Andrew C. Aitchison Kendal, UK
andrew at aitchison.me.uk
